Topic: buttstuffog gauge question.. (Read 1039 times) previous topic - next topic
What would make the oil, water and fuel gauge, all max out at the top of their range, then return to normal after a few minutes? Thanks, Herb.:bowdown:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
The voltage regulator on the back of the cluster.  It's a small rectangular unit attached to the circuit board via a snap similar to a 9 volt battery.  Pretty common failure.  As you face the back of the board it's on the upper right.
Until you get it replaced, I have found the guages will return to normal if you tap on the cluster.
Thanks. :bowdown:
