Topic: Thunderbird 5, team shameless 0 - need advice. (Read 1967 times) previous topic - next topic
Ok, so we've been trying to get this bird running. The motor sounds great, but we've been battling with the transmission.
A friend gave me his transmission out of a wrecked bird.  its also a c4, I found out it is indeed a c4.  tried the bell housing that came with it (shorter) it seemed too tight, even before bolting things down.  Tried my newer, deeper bell, and I cant get anything out of the transmission.  The wheels start to spin for about 3 seconds and then quit.  A friend told me that the 66 289's are different than todays. (I dunno)  He said that the torque converters were different and that the outer/male shafts were longer than they are now.  so far I'm throwing the B.S. flags on this, but, he knows more about these things than I do so who knows.
I do have a few questions.
(1) are the flex plates any different in dish depth, I know width, tooth ratio, and weights are different.
(2) is there any such thing as different lengthed torque converter shafts.
(3) if both answers to 1 and 2 are no, can somebody please confirm what size bell I need for this thing.  I'm getting kinda tired of pulling it out, and re-installing it. lol
86 Thunderbird TurboCoupe, 66 289 HI-PO, auto.
Hoof beats may be faster than heartbeats, but birds are faster than ponies!
6.25" bell is what you should have.  I've edited this post to show the pic of how I measured mine.  The spacer plate is more like 1/16" as well.  I assume the pump drive might not have been in all the way as mentioned.
1987 TC
its more like a 1/16 inch dust plate. lol  and I think I have both a 6.25" and a 6.75" bell (I have two bells.)  How many different bells are there for these?  I do have two c4's exact same trans. housings, filter screen covers, bolts etc. etc.
Are you saying you tried bolting the tranny to the engine but it wouldn't go? As in, the bolts wouldn't pull the tranny up tight to the engine? If this is the case, when this happens it's usually because the torque converter was not engaged into the transmission all the way. The splined input shaft may have engaged, but the slotted pump drive (the slots on the end of the converter) may not have. If you really came onto the bolts trying to draw it in you may have damaged the tranny's pump.
While I know there are different bellhousing depths and converters to match each, I don't have a clue as to which is which... Mustang II used a unique(small) bell/converter combo...
BUT you should be able to measure the depth of the converter in the bell... With the converter FULLY seated, measure from the bottom of the converter's threaded studs to the mating surface of the bell... Then from the engine(plate) mating surface to the flexplate stud openings... Allow a 1/4" less on the converter measurement, any more than 1/2" and I'd be leery of the bell/converter/flexplate combo...
ok, I'll have to go measure the bell again. lol I'm not sure yet.
We tried for about 20 min. to a half hr. to get the stupid  pump drive to seat. we couldnt get it for anything.  the splines were in there, but the pump drive wasnt.  Thats why my friend told me to check and make sure there werent different lenghts in pump drive shafts.
Man, when i swapped my motor, and went to put it back in, I tried at least three separate times to get my torque converter to seat. Finally I was telling a friend about all the hassle I was going through and he walked over, twisted it on the shaft and thunk! It seated fully. Of course, my transmission would not bolt up properly without the converter being seated.
Quote from: jrad235;290795
well, its easy to hook it up when you have the wrong sized bell, and theres room for the torque conv. to float around in there. lol
when seating the converter feel for the "3 clicks"  if you feel all 3 and it still doesnt seem to be in place then go on to the different bell.
thats the problem, we cant get that third click to save our butts. for some reason, we cant get the pump drive to seat.
have you tried rocking the converter?  when I seat them I wiggle and turn and wiggle and turn until it pops in.  if at all possible can you stand the whole tranny up on the tail shaft and use gravity to help it fall into place?  I have done this a time or two when I couldnt get them to go in. just make sure you do it in a drain pan or drain the fluid first.
