Topic: Cam degreeing - Needed? (Read 843 times) previous topic - next topic
Does every cam installed need to be degreed?  Or does lining up the marks enough?  I know for the high power engines, it makes a difference, but I'm talking about a stock rebuild.  The valves are closed at TDC, and rotate fully.
351W in the works
Quote from: bhazard;300566
You got woman'd.
On a street motor or stock rebuild just get a good quality timing set and install the marks lined up. I have used cheap timing sets and then checked the cam timing and it be a couple degrees retarded.
