Topic: check out my new rims...... (Read 3277 times) previous topic - next topic
Re: My '87 Thunderbird pics
Love the engine bay.
yah, the exterior looks like arse...i like my red interior though
whats up with the rear end (no punn intended)
air shocks... clearance for the extremely wide back tires.
nice car but lose the 70's drag look.
awww.... I guess you wouldn't like the old-school side pipes i was considering.....like the type on baldwin motion cammaros or amx's... :headbang:
I'll have updated pics of my car tommorow....
Quote from: tbirdmanjwg
Those pipes would look great!  I was looking at putting that B&M shifter in my cat.  How did the install go?  Any complications, or was it pretty cut and dry.
lookin good! I like the B&M also
being that my t-bird was a v-6 to start with i had the collum shifter. of corse i removed that and then installed the shifter by removing the center console and seat (one unit) and then drilled 4 holes for the shifter mounting holes and then bolted it down (had to reach around the trans. to install the nuts on the bolts).Then the linkage from my parts car was connected through a slotted hole i drilled for the linkage to go through the trans. tunnel.I had to make a few brackets for the linkage to attach to the shift lever on the trans. because the b&m pieces did not provide a smooth range of motion through all grears. It took a bit of tweeking to get it right, but it now works very good.
    If i stick with an automatic I will upgrade the AOD with a manual valve body so i can take advantage of the B&M shifter. :)
