Topic: tps (Read 3276 times) previous topic - next topic
tps
does any one know what color wire the tps is coming out of the computer? or what spot it should be in in the plug. also would the spot differ from a stock 5.0 bird to an a9l? its an 88 btw
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
tps
See if this is what you need.
tps
Quote from: Kitz Kat;289741
that would definatly help! but its too small to read.
i did a maf conversion and now i went to set my tps and the signal voltage is like 5, all the time while key is on. i must have messed up some where. and i am pretty lost right now. so any help at all would be aprietiated.
tps
PM me your email, I'll send you the full pic.
tps
It come in at 5v, sounds like you got the wrong wire.
tps
both the signal wire and the refrence wire are 5. i almost had to have wired something wrong
tps
This might work.
tps
It didn't.
tps
nope, still too blurry. idk if you can read it on your computer. can you tell which pin is the tps or what color it should be?
tps
Sig rtn#46 18g. black+white
Vref #26 18g orange/white
tp #47 18g. Dgrn/Lgrn
tps
thank you. but is sig return suppose to be ground and tp be that actual signal?
tps
ok. well i went out and checked it and all the wires are where they're sopposed to be. now im really stumped. would the tps signal be the same 47 position it is on a stock bird as it is on an a3m1/a9l? it didn't say i had to move those wires to do the MAF swap.
tps
They should be the same. I didn't change mine.
tps
this is confusing. well, at the tps, orange is + and black is -. but i guess green would be a ground right? the voltage i see should be after the tps and that should act like a resistor. but i dont think it can be a bad tps cause i've used two and gotten the same results. i cant belive i tested two tps's that both worked fine on cars just minutes before and now they are both maxed out. has anyone ever seen this ever?
tps
isnt green where your supposed to check the voltage?  this is where I have always set the tps on my TC but I'm not sure if its the same on a V8.
