Topic: 87-88 AOD TV cable found a NOS one. (Read 1664 times) previous topic - next topic
I need a TV cable for a 87-88 5.0 T-bird or Cougar that has a column shifter. It's a bit different at the end that connects to the AOD than a floor shifter TV cable.
I have a TV cable out of a '91 Lincoln Mark VII on my car and it works great. The cable came with the engine I got from the Mark VII. It even had the Brass TV bushing and pin.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
Is your car coulmn or floor shifted? The column shift cars have this goofy cable/bell crank TV set up. I might try a TV cable from a floor shifted fox (Mustang or Mark VII) to see if it works but I'd like to see if I can find the correct column shift cable.
My car is a column shift, but I believe the cable came from a floor shift Mark VII.  I believe all Mark VII's in '91 were floor shift.
1988 Thunderbird
Well if it works for you it should work for me. Now I can get rid of that goofy bell crank set up:hick:
Mine still uses that goofy bell crank setup.  The TV cable runs from the TB to the bell crank setup on the trans.  The bell crank then actuates the TV lever via a rod.
1988 Thunderbird
Quote from: 88BlueBird;289488
That's the set up mine has. I thought the cable from a floor shift car was longer but I guess not if the one from a Mark VII fit.
I'm still looking for a stock 87-88 5.0 TV cable as the yards by me don't have any fox 5.0 cars. Someone is bound to have one and save me the trouble of digging one out from a car at the wreaking yard, if I find one ;)
I'll check the yard Saturday morning.I think that the one 5.0 '88 Bird still has it connected to the tranny.
You need the kind of cable that has a T-5 attached to the end of it! :burnout:
Good luck with the search, sucks I just trashed two TV cables.
Quote from: vinnietbird;289554
If so could ya grab it for me? Finding a 5.0 fox car in the yards up here is like finding a pot of gold at the end of a rainbow. :hick: I can't even find a 5.0 HO Mark VII let alone a 5.0 Mustang.
I no longer need one. I found a NOS TV cable at a Ford dealer in Kansas. It should be here Thursday :D
Wow....good find!  If you don't mind me asking, how much did it cost at the dealer??
1988 Thunderbird
Cost of the cable is $94
Cost to ship it to Chicago is $8
Total cost $103:hick:
Yes I am crazy:crazy:
Not bad for a NOS Ford part...there can't be many left. Look at this way...you shouldn't have to replace it again for at least another 20 years :)
1988 Thunderbird
