Topic: quick and easy, motor disassembly question (Read 1238 times) previous topic - next topic
When taking the valvetrain out for a cam swap, do the pushrods, lifters and rocker arms have to go back in the same posistion/valve as they were prior?  :hick:
Mike
Yes.  But, make sure there's no wear on either the pushrods or the lifters.  You are talking stock replacement cam, right?
Armed Forces Car Club
Eastern Sierra Chapter, California
WEB:  armedforcescarclub.com
Yea, stock HO cam.
Mike
NO.You don't have to install the roller lifters in the same spot on a roller engine.you can dump it all in a box (just being extreme as an example),and re-install the parts.No worries.
Thanks Vinnie.
Mike
I just cut up a cardboard box for this.  Make slits for each part in the respective location, then draw "FRONT" and "REAR" on the proper end of the box.  Stick the parts in the slit for the box to hold, put it somewhere safe, and continue working. :)
I'd try to reinstall the parts in the same position, but with a roller cam it isn't absolutely necessary...
^^^ I agree with him.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
