Topic: Plug identification near ECU (Read 1305 times) previous topic - next topic
ok i found 3 plugs near the ecu mounting location in the bunch of wires.  I was curious if someone could tell me any idea what they are by color code wires
they are as follows
Grey plug, wires... white with pink stripe, Purple with Yellow stripe
Grey plug, wires... white with pink dots, purple with green diagonal stripe
 Grey Plug, Wires... Dark green with orange stripe
Light blue with white diagonal stripe
White with green diagonal stripe
Orange with gold(they look goldish) diagonal stripes
I do also have a brown plug found behind glove box near the door. it has a relay on it and would like to find out what relay it is.
 brown plug. the wires are
Black with Yellow stripe
(2) black with orange stripe (going to same pin on plug)
Black with green stripe
Red with Blue stripe
I hope this is enough information to figure it out.
Thank you
The relay is the EEC power relay.
ah ok thank you i wanted to know cause the relay is cracked.
Lemme know if you find out what those mystery plugs are.  I noticed them too, and wonder what the heck they're for.
:birdsmily:
well if i can get down to my EVTM after im done with the state fair on sept 8th ill try and look on that
