Topic: TC 5.0 swap (Read 3593 times) previous topic - next topic
TC 5.0 swap
since I am swapping in the 5.0 and going the EFI route I have come to the question of the fuel pressure relay.  since the TC FP is controlled by the IRCM module will I need to add a relay or is there a relay somewhere that I am unaware of?  looking for Tom or someone else that has done this swap to chime in.  Thanks
TC 5.0 swap
Yeah,I've done that swap and I know what you're dealing with.I just can't remember off the top of my head what I did.It's a simple "pin swap" deal near the ECM.If you can hang on I can check my notes tomorrow and I'm sure I can tell you what to do.
TC 5.0 swap
well I have done some digging and I found some info in a post from Dominator "Fuel pump wiring harness from the computer to the rear form an 87-88 bird or cougar,with relay"  so I guess I am on the hunt again for some more wiring. :(  this is whats gonna hold me up, there are no fox cars in any of the junk yards here.
TC 5.0 swap
I should have asked first,what are you swaping in? a 5.0H.O.? The reason I remembered it being simple(for me) is because I bought an entire 93 Mustang and used the engine harness etc.I just had to get the T-Bird wiring to "talk" to the Mustang ECM.I have the'88 T-Bird elec.-vac.manual from Helm if I can help you.Let me know what you're doing.
TC 5.0 swap
5.0 mass air into an 88 turbo coupe.  I have the HO intake, shorty headers, edelbrock cam, and a stock 85 302.  not really sure if my combo will work or not I just need to get the wiring under control.
TC 5.0 swap
here is something to chew on.
I know exactly what you are after though.  Go to the fuel pump section and you will see how the EEC relay is in control of it. you have to flip to the next page to see the splice point that is fed by the eec relay.  the splice point comes back to the previous page and rolls through the coil side of the fuel pump relay.  That energizes the fuel pump relay and makes the contact close ,, from there the fuel pump kicks on.  THis really aint that hard to figure out,, just compare the 2.3 chassis wiring and see what you come up with.
 http://s47.photobucket.com/albums/f162/jcassity_bucket/
TC 5.0 swap
Looking at the 87 EVTM and hopping this is close enough to your situation:
The 5.0 has the fuel pump relay in the trunk and three wires running from under the right side of the dash to the trunk to control the relay.
The 2.3 Turbo has the Integrated Control Module up front and one wire running to the trunk for the fuel pump.
Installing a relay under the dash and using the one wire to the trunk for the pump looks like the way to go.
The 5.0 harness should have a 4 pin connector under the right side of the dash with red, yellow and tan/light green wires.
These are the three fuel pump relay wires.
In the area of the EEC module there should be a 4 pin connector with a pink/black wire in it.  This is the wire to the fuel pump.
Here is what you wind up with:
TC 5.0 swap
leme modify that a little to include what i mentioned earlier about you having to look at the next page.
softtouch
I like where you put the inertia switch, makes better sense there in my opinion.  having it on the coil side of the relay always made me wonder "what happens when the contacts are sticking.
TC 5.0 swap
Quote from: jcassity;289016
I didn't move the inertia switch, I just changed the drawing to show where it is if you use the existing Turbo Coupe fuel pump wire.
(page 61)
TC 5.0 swap
well I am working on the repin of the grey and black connectors as per Dominator's write up and I have ended up with a few wires that were not listed and I am unsure of where they should go.  the wires that I have left over are:
Orange/yellow
White/Red
and then the ones listed by dominator
Black
Grey/White
Green/purple
any help here will be appreciated.
here is the link to Dominator's write up http://www.foxtbirdcougarforums.com/showthread.php?t=1218&highlight=TC+5.0+swap
TC 5.0 swap
red/white is the connection for the temp gage... Black is usually a ground...
Gonna take some digging to find the others...
TC 5.0 swap
Quote from: softtouch;289057
(page 61)
I did same on my swap but the F/P relay is in the trunk same as original 5.0(I used a complete Bird 5.0 harness)... I just connected the power from the relay to the inertia switch same as orig to TC... I used the single TC F/P power wire to connect the the F/P monitor circuit on the MAF EEC...
TC 5.0 swap
Quote from: TurboCoupe50;290150
did you mean white/red?  this is the wire that I am unsure of.  does this wire go back with the grey/black connectors? if so where?
TC 5.0 swap
Oops the white/red is the oil pressure gauge hookup...
I just looked at mine and I have no connections on the gray plug at all(it's just hanging the or/yel is in it)... Black plug is is mostly connected... I fabricated adapters from the 5.0 Bird body harness and the 2.3 engine harness and just plugged everything in... Been 10 years though(fall '99), I have a hard time remembering exactly what I did...
Can't seem to find my EVTM, was loaned to a buddy and I'm 99% sure he brought it back, puzzling why I can't put my hands on it...
