Topic: Shorty headers and oxygen sensors (Read 2953 times) previous topic - next topic
Do shorty headers...such as the BBKs...have a place for the factory oxygen sensor to screw into??  Most long tubes that I've looked at have a bung near the collector then you have to buy the extended sensor wires.
I'd rather just install shorties and use a standard fox body H-pipe w/ cats (required for inspection).
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
mustangs and mark7's have bungs in the hpipe assembly. You can also buy a kit to extend the o2 sensors, or just extend them yourself.
I dont know for sure but I would think that since the stock shorties use the H-pipe for location of the sensors the BBK would be a replacement and wouldnt have them.
You'll need to extend the wires even if you use stock Mustang shorties. T-Bird/Cougar manifolds have the bungs in them, while Mustangs (and any aftermarket headers made for Fox Mustangs) will not have any bungs, they're further downstream in the H pipe.
Thanks...that's what I was looking for!
Anxiety put to rest.........
If you need new o2 sensors, just buy the ones with the longer wiring.
Mike
It probably would be a good idea to just go ahead and repalce them anyway
FOXLESS!!
1994 Lincoln Mark VIII
Quote from: Thunder Chicken;288571
I have Mac equal length shorty headers and a Mac H-pipe.......I do not run any wire extension on the o2 sensor harness.  I use the Bosch oxygen sensors that come with the 12" wires.  It makes for a cleaner install with less connectors.  Your local parts store should have them in stock.  If not they can order them.  If not, it's time for a different parts store ;)
