Topic: TC rearend - "grinding" noise (Read 9380 times) previous topic - next topic
Reply #60
It was a clunking noise. Felt like a wheel was loose when almost stopped.
:burnout:
Reply #61
I had a grinding noise in my rear brakes and it turns out I installed the rear pads incorrect.  For some reason (I hate to admit this) I brought the sping clips up through the holes in the top of the calipers, I guess I thouhgt that what kept them in.  Turns out they are there to push pressure down on the pads and the spring clips need to stay under the calipers.  I got new pads and installed them correctly and all is quite and good.  Also there are some thin pieces on the sides that slide in.  I was not able to fit one on each side and only used one of them.  There was no way there was enough room for both.
Just passing on my mistakes.
TED
Reply #62
Quote from: Cad-T-Bird 500;293580
TED
It's always good for the less experienced among us to read things like that, because it can be hard to find basic stuff like that online, since everyone assumes everybody knows it already.
Reply #63
So Seek, did you ever take it apart and fix it?
I just swapped in my new rear last week, and when i was taking the old one out I tried turning the axles with no wheels or brakes and it sure felt like the pass side axle bearing was toast.(Not suggesting that's what is wrong with yours)
I guess I should take it apart for the hell of it, not like it's worth anything to anyone with 190k on it.  :D
Reply #64
I bet you take the wheels off and the calipers if you have them, you got some play side to side on that. you may say you checked it. but you better look at it again.
Reply #65
Quote from: Kitz Kat;302700
I don't suppose you'd mind explaining yourself a little more clearly?
Reply #66
I wish I found this sooner!! Mine does THE SAME THING. If your on the gas the sound is low, you let out it gets loud. take a turn slow its not bad, take it FAST and it gets worse. If the tires spin then drivers side tire trys not to and it makes a HUGE banging noise. T lok is coming apart in mine im almost 100% possitive, either that or I have a HUGELY defective tire.
Reply #67
As stated earlier, it was the carrier bearings. The traction-lok was fine but it was rebuilt when I had the rearend apart. I still hear some noise back there but it's very faint (I have to listen for it) and likely normal. Coming from the 7.5" that had a whine over 45mph for over 10 years, I can't complain.
The sound I've got now is similar to the sound I hear from the front wheels when I don't have the kickpanels/insulation on that I can't hear from outside the vehicle or inside with the insulation in place.
