Topic: dropped spindles (Read 4074 times) previous topic - next topic
dropped spindles
Hey everybody,I saw in the new 5.0 magazine that racecraft is making 2 inch dropped spindles for 79-04 mustangs.I thought this would be a cool mod(assuming they will fit our cars)for those who could afford it.They list them at $495.00 a pair.
Joe
Re: dropped spindles
Yikes!  That's a steep price!  Still, drop spindles would be an easy way to drop it down without touching the springs.
wouldnt that bring up clearance issues with the front lower control arms?
Quote from: Manson
I would've thought it would. There isn't much space between the lower control arm and the rim as it is (it's so tight that with 14" wheels a loose ball joint can cause the control arm to hit the rim!)
looks like somebody thought they had a good idea, but its turning out to be a ghetto rig quick fix
Well, I would imagine folks would be running at least 17-18" wheels with that type of set-up anyway.  There is more clearance obviously.
The only other option is to raise the inner mounting points at the chassis, but that gets out of the realm of most folks abilities.
What are these spindles supposed to be spec'ed for? Road racing?  Drag racing? looking cool?  Do they upgrade the hub bearings?  The stock SN-95 bearings tend to die early deaths under hard track usage.
I'm not sure about that.They were listed in the new products section so not much of a description was given.
Joe
