Topic: electric fan (Read 2117 times) previous topic - next topic
electric fan
So what kind of electric fan is everybody using on thier fox cougar? I would really like to install one on mine. I have one from an mark viii, and it is too thick to fit in btween the radiator and engine. :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Re: electric fan
I modified a 1988 taurus electric fan, to fit my application.  You can try the 94-94 stang style fan but, it may be to thick to fit between the pullies & radiator depending on how your motor mounts are setup.
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Re: electric fan
got mine from advance auto. I think it's a proform, not really sure, i'll have to look, but it's 16 inches and i also got the t-stat. You can definatly see a differnce in cooling and I felt a difference in acceleration the first few times i drove it.
Re: electric fan
Thanks guys, I was loking into getting one of those Taurus fans. :D
