Topic: Mixing different finish paints (Read 4534 times) previous topic - next topic
Heres the deal
Rustoleum from Home Depot (you can spray it)
2 cans of flat black
1 can of gloss.
Want a satin/semi finish.
Would a 1/1 mix archive that or would there need to be more flat to offset the gloss?
It is going on a beater DD that just needs something to cover the worn stock paint.
Was thinking a 2/1 mix but Jerry thought it might be too much.
Any thoughts?
start with the gloss and add a bit gradually and see how it dries.
you'll be able to control the amount of gloss that way.
Are you using quarts or gallons?
Quote from: daminc;286728
Believe gallons. Its one of the local SHO guys cars.
why not just get the semi gloss ?
Quote from: SLEEPER T-BIRD 87;288874
There you go. If you got it at home depot, return it and get the semi
Didnt have it. The car is sold now though so no worries
