Topic: 1987/88 turbo coupe (Read 652 times) previous topic - next topic
1987/88 turbo coupe
need rear window clips.outer wide moulding, bottom of window.
these are plastic, about 1/2" wide  six needed.
power lock door actuators needed 2
thank you.gene
email adress : genelott@hotmail.com
live south of detroit, no good ones at salave yards
zip:48179
1987/88 turbo coupe
is yours an 87 or 88?  87's have the metal trim around the rear window and 88's have a rubberish trim.
1987/88 turbo coupe
Quote from: 88turbo;285684
Are you sure about that? I thought I saw a thread about manufacturing overlap where some 88s had metal or some 87s had rubber. You're probably right, I just kind of wonder about the accuracy of "all 19xx had this" because Ford did so many weird things throughout the years.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
1987/88 turbo coupe
have more info it"s a 1987 turbo. build date 4/87
bottom trim is metal approx 3" wide with rubber strip on top .
pic coming soon,
clips are small button made of plastic
1987/88 turbo coupe
I will check on my 87 TC that I am parting to see what shape they are in
2015 Ram 3500 MegaCab Diesel
1986 Thunderbird Elan 302 Crate, x303 heads, e cam, 24lb injectors, gt40 intake, WC T-5, TC rear w/ 3.55 gears, CHP control arms,cobra r wheels.
