Topic: More great parts...Buy it all.......... (Read 2679 times) previous topic - next topic
I have one more 3G alternator.....$45.00
4 V-8 distributor covers........$14.00 each shipped
19# injectors (new o-rings,screens,pintle caps).....not used since new kits were installed......$55 shipped (for 8 of them)
8-----19# injectors....33,000 miles on them,4 hole design,excellent shape......$30.00 shipped----SOLD-----
Console "cubby" container...(2 of them)......$12.00 each shipped
storage shelf above radio (I have 3)........$13.00 shipped
Headlight switch (I have 2 of them).....$12.00 shipped
Auto lamp switches (I have 2)....$12.00 shipped
Auto lamp/headlight switch panels..( I have two)...$8.00 shipped each
Fog light switch........$10.00 shipped
Passenger side inner fender hole plug (that round black disc plug,about 4 inches in diameter).....$10.00 shipped
Many very good IAC's......$14.00 shipped (each) smaller ones and stock sized ones)
Stock Cougar horn button....$10.00 shipped
2 passenger side signal light assemblies (not foggy,very nice)......$25.00 shipped (each)
One tan vinyl Sport seat headrest....excellent shape.....$25.00 shipped
Misc dew wipes....$40.00 shipped per pair
Very good TPS (2 of them)......$12.00 shipped (each)
Lincoln Mark VII stereo amp (factory).....$25.00 shipped
Hood to cowl seal.....$15.00 shipped
No power anything console control panel....blank....$20.00 shipped
Only power window console control panel....$20.00
2 console trays (for column shifted cars with a console)....$15.00 each shipped
1 set of chrome lug nuts (I had them on my Cobra R wheels).......$15.00 shipped for all 16.
Factor style 65 amp alternator (Autozone lifetime warranty)...about 500 miles on it....$40.00 shipped
Factory Turbo Coupe valve cover "Fuel Injected Turbo" embossed on it.....$55.00 shipped
stock 5.0 fan and nearly new fan clutch clutch has about 200 miles on it).....$45.00 shipped
Full digital gauge cluster.....$40.00 shipped
JUST ADDED>>>>>>>>>
-complete AOD Sport floor shifter/cable/cable bracket....$80.00 shipped
-A9L Mass Air computer.....$120.00 shipped
73mm Mass Air meter/sensor.......$40.00 shipped
-5.0 Injector harness.....$30.00 shipped
If you have any questions,let me know.
More coming soon...................
Are they 95 or 130 amp?
2003 Marauder 300B
1996-97 Cobra wheel straight but weathered (For Sale)
84 TC manual shifter handle no  (For Sale)
BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
Special thanx to EricCoolCats for showing me to this site.:bowdown:
A lot more added.
Is the headlight switch w/ or w/o auto lamp? The same goes with the fog lamp switch.
2003 Marauder 300B
The auto lamps,head light switch,and fog light switches are all separate switches.The headlamp switch with swap into a car with or without auto lamps.Same with the fog light switch..
I see. Thanx for the info.
BTW, the alternator is very tempting.
2003 Marauder 300B
I'm easy to find.
I see that. I am planning ahead as the XR7 that I am looking into has a charging problem and is a prime candidate for this mod.
2003 Marauder 300B
I did the 3G upgrade about 3 years ago or so.Still using the same alternator,and it was one of the best upgrades I could do.Now,in the winter time,headlights on,heater,radio,defroster and fog lights,no charging issues at all.
One alternator gone.
How hard it the swap to a 3G?? I know I can research it but am wondering from those who have done it... I am interested in your last one..
:ford::oldcougar::mercury:
It took me about an hour to swap mine.I had to cut a small notch in my alternator bracket (took about 2 minutes with the trusty Dremmel),a hacksaw would work.Then the wiring,which is also pretty easy if you just follow the instructions posted elsewhere here.
I got 3 PM's and promptly deleted them.Sorry guys,Pm me again.
Sold two,added three.
