Topic: 87-88 Passenger window guide (Read 660 times) previous topic - next topic
I need the metal wndow guide with the rubberized insert for the passenger window, the one towards the front of the car. It should be easily removable. Does anyone have one? I've had it with my window either getting stuck or coming off the track.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
do you have a pic of it? I probably have one or two
Not handy, since I'm at work typing this on my phone. It's an aluminum U-shaped channel with a bolt at the bottom, about a foot long. I think it clips into something at the top, but it's been a while since I looked at it. There's a rubber/felt liner that fits into it that serves as the window guide. I need both parts.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
I have it if Jerry doesnt
I'll check them out tomorrow for you.
Thanks, but dansbirds is going to send me one. I took a look behind the panel and it looks like I actually need a rear one instad of a front one. I'm missing the rubber liner, I think it was taken out because the window kept getting stuck, but it might be causing the window to come off the track up front.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
No problem,
If you need other misc. window parts, I have them too.
