Topic: Y303 Aluminum GT40 Heads F/S (Read 1238 times) previous topic - next topic
Blew a head gasket the other day and decided to finally install my Twisted Wedges so now I have these Y303's to sell. They are machined with reciever grooves so a wire-loc head gasket is required such as a TFS-51400901 or equivelant. The heads use the stock pedestal bolt down rockers. I will include all the shims that I have (they install under the rocker fulcrum and are used to achieve proper lifter preload). You may or may not need them with your combo.
The engine was never overheated with these heads and they are ready to bolt on and go. If you want a cheap set of aluminum heads that are supercharger ready these just might be your ticket.
I'll take $500 plus shipping from DFW, TX.
Haven't cleaned 'em up but just took some quick pics.
PM me if interested.
I wish those would work with flat top pistons.
Yeah I know, they've got 1.84 intakes I believe. My pistons have the 4 eyebrows. So you'd need HO pistons. Wont work with the SO flat tops. I figured I'd give the guys on this site first crack at 'em before I list them on the Corral or DFW stangs.
I'll keep 'em up here for a few weeks though in case someone could use them. My car ran really good with these heads, they dont kill your bottom end at all :)
Quote from: vinnietbird;284970
there's gotta be a solution to flat tops, seems like i would have shaved the middle of each piston (shop costs) down to negate the possibility of valve float in sacrafice of compression ratio  ,,or shaved the pistons totally to comp for the interferance.
what did these heads come from?
Quote from: jcassity;285331
Yea get new pistons or flycut your current ones as was already implied.
They came from my 86 T-Bird of course, lol... They were on an FRPP crate engine. The engine has pistons with a shallow dish and four eyebrows.
You could also get a pair of trickflow heads, which do not use the same angles on the valves, requiring not valve reliefs on most engines.
Yeah but that doesnt help him because then he still has heads and no $500 :hick::rollin:
true, I was too far into the tech aspect when I posted. These would be a good upgrade on any stockish mustang or cougar, if you have vavle relifs.
Local sale pending. I'll update the thread if it becomes final.
