Topic: Car was idling, took PS pump out put new one in.... (Read 934 times) previous topic - next topic
It won't start! Firing order is correct, alternator is correct, belt is tensioned fine, what am I missing?
oh btw this is for the Turbocoupe
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Take a good look all around where you were working. Go over all the items that are needed in that area for the car to run. You may find that it is something as silly as the coil wire being knocked off or a pinched wire.
If you do not find anything obvious, go back to basics:
Does it have fuel pressure?
Does it have spark?
Is the cam turning?
This sort of thing can be very frustrating! Step back and check one thing at a time and you'll get there.
Shiny Side Up!
Bill
As stated in the above post, look for the most obvious.
An internal combustion engine only need 3 things to run...air, gas, and ignition.
Check that you are getting 12 volts at the + terminal at the coil with the key on.
Fuel pressure is easy to check....just push in the schradder valve and gas will squirt out if the fuel system is pressurized.
Alot of times it turns out to be a simple item that either fell off or was left off.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
firing order was wrong. (I looked at the diagram wrong) I fixed it and now shes runnin
Thanks!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
