Topic: Fluid Compatability (Read 1308 times) previous topic - next topic
Fluid Compatability
Is the trick shift Trans fluid by B&M compatable with the ford AOD? If not what fluid do you guys recomend in this trans.  My application is offroad use only very wet, muddy, and rocky!!!!!!
This is the Freak otherwise known as "Thumper"
5.0HO/AOD 91' T-Bird
MT Classic II 15x10
Goodyear Wrangler 33's (Switching to 35 or37's)
6-8" Suspension/5" Body Lift
91' Explorer Axles (Regearing to 5.17's)
http://photobucket.com/Mystic4x4s_Thumper
Fluid Compatability
I think that stuff eat threw any tranny, it does what its suppose to do but i wont put it in an every day driver.
Fluid Compatability
I ran it in my SC for years.  Haven't had a problem.
Fluid Compatability
http://www.jegs.com/p/B-M/B-M-Trick-Shift-Trans-Fluid/749362/10002/-1
it states it meets and exceeds automatic transmission fluid
cut and paste of jegs website
B&M Trick Shift Trans Fluid
Product images may differ from actual product appearance.
Pour In Performance!
Ideal for racing, performance street, RV and heavy duty applications.
Not an additive!
Works with all transmissions when a firmer shift is desired on 1997 and earlier vehicles. Not recommended for 1998 & newer applications.
B&M Trick Shift Performance Automatic Transmssion Fluid (ATF) is the easiest way to firm up your transmission's shift performance. Not an additive, this safe and effective blend of extreme pressure agents and foam inhibitors will provide a noticeable shift improvement when you replace your existing automatic transmission fluid with Trick Shift. Ideal for street use and high load applications such as racing, off-road, towing and heavy duty fleet use. Trick Shift may be mixed with other types of ATF but works best by itself. With B&M Trick Shift you can literally ''pour in performance''. Meets or exceeds Type F requirements.
