Topic: Fuel readout question (Read 1901 times) previous topic - next topic
I was drivng the other night and my fuel gauge went from reading 19 to C 5. Has this happened to anyone else. It's an 87 XR-7 with full digi gauges.
Junkyard Cat
hexadecimal code is being displayed,,, which easily converts to binary but who cares bout that stuff.
Tach/Multi guage diagnostic
all codes are Hexadecimal format and can range from 00 to FF (binary 0000 to 11111111)or (decimal 0 - 128)  . While active in the various modes, they can be used as a "wiggle test" to check for shorts and intermittant circuits. Anyway,, display will be in hex format.
hold the guages button in and turn the ign key to RUN
Advance through the tests by pressing the guages button.
A steady Tone and 8 bars lit is a passing test
No tone with 24 bars lit is a fail
To enter the Fuel computer self test
Press and hold the Select button atleast 5 or so seconds until the test display appears then advance thru the tests by pressing on Select over again.
What else can you do in there?  My fuel readout displayed CO when I last filled up.
Does it time out to exit, or do you just turn the key off?
Mike
My digi fuel gauge also reads CO sometimes. I will have to try JCassity's test procedure.
Please let me know if you find out what causes this.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
all i've figured out so far is that my car failed every test
Junkyard Cat
then check the resistance on the fuel sending unit.
Fuel sending unit info
87 Evtm page 127 or 129 shows
Empty - high resistance - 60 to 86 ohms
Full - low resistance - 8 to 12 ohms
87 shop manual 33-20-1 shows
Empty-low resistance-22.5ohms
Full-high resistance - 146 ohms
new sending unit fixed the problem, thanks jc
Junkyard Cat
glad it was'nt the fuel computer,
the sending unit is pretty easy to fix though, the wiper arm is exposed to the coil that changes the voltage.
