Topic: 351 Question (Read 2807 times) previous topic - next topic
351 Question
For those of you with 351's using sepentine belt drive, are the brackets for the accessories 351 specific, or interchangeable between 351 and 302? Just working on my swap list, and figured this was a good time to get this part outta the way.
Thanks folks! :D
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Re: 351 Question
The alt/smog bracket is same, p/s & a/c is different. I believe you'll need the Mustang type p/s pump mount(on the pump) as the Bird/Coug mount won't fit the 351 bracket.
Re: 351 Question
I only run crank waterpump and alt all on one sepentine belt.
I used mustang underdrive pullys and made my own alt bracket
Re: 351 Question
Hi guys, sorry about the delayed reply, but thanks for the answers. I'll need to keep my smog pump, but the a/c already went buh-bye. I'll be looking into a Procharger unit, but need to check with them about mounting solutions.
Their website doesn't mention 351's, but the pic they show for the 5.0 has the a/c in place, and the supercharger beside it. Easiest mounting for routing their intercooler I guess. Need to find out if they offer mounting brackets for non a/c apps. with a 351.
Thanks again guys! :D
Resident "Idiot".
Quote from: Big_D
