Topic: BM's 88 Cougar build (Read 45628 times) previous topic - next topic
Reply #195
when you refill the trans with fluid, dump in a quart of lucas oil trans fix or stop slip or whatever they call it.. i always use it at any sign of transmission problems and it really works great.. best way to do it is to premix it with trans fluid or else you'll spend about 5-10 minutes squeezing the bottle and waiting for it to slide down the trans dipstick.. just dump half of 2 quarts of trans fluid in and split the lucas between the 1/2 quarts.. then just give it a little shake to mix it up a bit and dump it in.. i also HIGHLY recommend a new trans filter.. god only knows if they current 1 is the original or a replacement
Reply #196
Quote from: thunderjet302;375956
Is the TV cable properly adjusted?
X2...
No point in fixing it if the tv cable isn't hooked up, or not adjusted correctly.
Reply #197
X2...
Reply #198
The TV cable is adjusted correct, I checked it when the transmission started acting up. If the TV adjustment was off why would it be shifting fine now? I would never drop the pan without replacing the filter, the shift kit comes with one anyways. Im going to clean the valvebody while I put the shift kit in and check to make sure there are no sticking valves.
Reply #199
DON'T USE BRAKE CLEANER.. it leaves a residue behind that may potentially eff your day up lol
Reply #200
Does anyone now how to tell the difference between the early model and late model AOD. My shift kit has two gaskets, one for each. If I use the wrong one the kit says it will F-up the pressure and burn the transmission up.
Reply #201
hmm.. is the kit AOD-E compatible? should be able to match the gasket up to your old 1 and figure it out.. you should also do the epoxy mod while you're at it
Reply #202
Well I still havent been able to work on the car, Ive only had four days off since the new year. But I do have an update that might not make everyone happy, my cougar might be going up for sale because I have a lead on a 68 XR7 with a 351C. I needs alot of body work but it has a good tranny and a rebuilt (by The Head Shop) 351. Did those cars come with an FMX or a C4?
Reply #203
Quote from: ClassicCougar.com;383214
The automatics offered in Cougars were the C4 (used with small block engines in 1967 and 1968), the FMX (used with 351 CID engines beginning in 1969), and normal- and heavy-duty versions of the beefier C6 transmission (the normal-duty C6 was only used in Cougars with the 390 2V engine, while much more common heavy-duty version was used with high-performance, large displacement engines, like the 390 4V, 427, CJ 428, and CJ 429. The identifiers for these transmissions (C4, FMX and C6) were Ford's in-house nomenclature
Most likely a C4 since its a '68
Reply #204
Well I was talking to the guy last night on facebook about his 68. It seemed to be going ok until I asked what he wanted for the car and he never replyed. Weird!
Reply #205
OK!! Im finally going to have the weekend off. So I'm FINALLY going to install the gears, posi, and shift kit tomorrow. I can't wait. I've only had the parts laying around since before christmas. Im hoping it will be night and day, I'm kinda not impressed with the new engine right now. My next step will be the headliner, floor shifter, exhaust, and factory hub caps.
Reply #206
hubs caps? why hub caps?
Reply #207
Quote from: Shadow;385033
Wire hub caps, to look stock. Im keeping the turbines to play.
Reply #208
I got the gears in today but I might have to take it back apart. I rebuilt the posi and I think it might be too tight because its popping when I turn.
Reply #209
The posi is fine now, it cleared up after some driving. Has anyone had any fitment issues with Pacesetter headers and H-pipe. I found a good deal on headers and h-pipe so I ordered them, just wondering if there are any issues with them.
