Topic: BM's 88 Cougar build (Read 45645 times) previous topic - next topic
Reply #165
One piece at a time.
Reply #166
Quote from: Bruce M;371252
The lug nuts are tight and the tires have 33 pounds in them. I think its the sidewalls. You can push the rear side to side and see the sidewalls flex. I might pump the tires up to 35-36 pounds and see if it helps.
I had some old dry rotted tires on my bird, and it did the same thing. New set of tires, and it was fine after.
Reply #167
Quote from: Haystack;374400
They're brand new. Maybe I got used to it because I dont notice it that much anymore.
Reply #168
Try putting more like 38-40 psi in them. Or run what the tire says on the side.
Reply #169
Run what the tires says to run. If you want stiffer tires, get tires with a lower profile and stiffer sidewalls.
Reply #170
Im going to either start gathering parts for a T5 swap or a built C4. I held her in first gear for her first 6K RPM pull and when I shifted to second it slipped pretty bad. Im tired of AODs, this is the second trans I've put in this car. Im surprized it pulled hard to six grand, I held it until it flattened out which was about 5800. I thank I'm going to put a C4 in it with a 2400 - 2600 stall. A T5 would be funner to drive but with my future plans a T5 will not hold up.
Reply #171
C4's<3 i don't care what anyone says, C4's are better than AOD's
Reply #172
As long as you don't care for overdrive.
Reply #173
OD is nice.. for some people, but i think they suck, majorly.. you can make up for it with a performance lockup converter
Reply #174
4R70W FTW.
I am luvin' the one I got so far.  Of course I haven't had a chance to abuse it, but it is the end result of Ford developing the AOD.
Bellhousing and trans set me back about $500.00
Reply #175
Do they make controllers for them?
Reply #176
bauman does.. i can't know the 4R70W, ford got their game in order after the AOD and put together a decent transi just don't like the fact that it's computer controlled, but that's where the controllers come handy
Reply #177
Quote from: Bruce M;375070
Yep, like Shadow said. Baumann Opti-shift is what I am using. It costs for the electronics, but then you save on the hard parts and gas.
If a person wanted/needed OD, I believe all the best arguments would be for the 4r70.
Reply #178
Quote from: flylear45;375088
agreed.. i posted a thread on SBF tech asking about AOD upgrades and everyone praised the 4R70W, so i looked into them.. definitely a better trans by a long shot. if you add it all up, it's cheaper to get a 4R70W with a controller than it is to beef up and AOD with performance parts.. like they say, you can polish a turd, but it's still a turd.. i like the C4 because it's a lot like the AOD, minus the trashyness and OD.. C4's also take a LOT more abuse as you add power. i ran a STOCK 140k mile C4 (nothing but a shift kit) in my capri for about 2 months before it died, and i'm pushing a lot more than the 450hp they're 'rated' to handle.. an AOD would have died in 2 days, max
Reply #179
What about the AODE. I havent heard good or bad. I'd like to keep OD but I cant stand the TV cable. How much are the 4R70 controllers?
