Topic: X vs H pipe, any benefit over the other? (Read 5632 times) previous topic - next topic
Reply #45
What I mean is,they'll make a difference over stock parts easily,but between the H and X,I don't think you'd tell a difference.If you removed an off road H-Pipe,and replaced it with an off road X-Pipe,I think you'll hear a difference,but not feel a difference.
Reply #46
Quote from: dominator;285229
Not sure about that,i always heard x pipes where better for low end torque.
I've heard the exact opposite... :dunno:
I've also heard that the X will usually be quieter....
Yet another interesting read:
http://www.carcraft.com/techarticles/exhaust_system_installation/index.html
....the guys had built a really trick system consisting of 2-½-inch tubing from the header collectors into the X-pipe, 3-inch out of the X flaring into 3½-inch tubing running for about 26 inches before necking back down into a pair of 3-inch lers with turn-downs. The theory behind this design is that it will keep the velocity of the exhaust gases moving quickly through the headers into the X-pipe to maximize the scavenging effect, while the larger-diameter tubing ahead of the lers prevents the gasses from stacking up as they pass through the lers to avoid excessive backpressure in the system.
Reply #47
I agree that the X-Pipe would be quieter.....but,that kind of depends on the chosen lers in the end.
Reply #48
Well, let's say that the headers and lers were unchanged then ;)
Reply #49
Well,in that case,I'd say the X-pipe would be more quiet than the H-Pipe............but you still wouldn't feel a difference between the two in the seat of the pants.LOL.
Reply #50
I'd like to see averaged HP/TQ numbers across 2500-6000 RPM between an x pipe set up for my current exhaust and my existing H-pipe.....
Over a span like that -- you WOULD feel a 10 average hp/tq difference.... ;)
Peak #'s are for advertising.....Average #'s are for driving:burnout:
Reply #51
That's a good question.I'd like to see the numbers as well.I'm sure that 5.0 mag or MMFF has done some kind of testing.I may try to find that afterwhile.I'm using the X-Pipe and like the sound better than the H-pipe I had.Send me your H-Pipe,and when I hit the dyno again I'll get the numbers and then send the H-Pipe back.........LOL.
Reply #52
They're both better than the stock Y pipe. Case solved :p
1988 Thunderbird Sport
Reply #53
I can live with that.
Reply #54
Perhaps I should also add CRUSH BENT tubing. The stock setup is about as bad as you could get.
Exhaust manifolds - alright
Crush bent Y pipe - bad
Single small catalytic converter - horrible
Another Y pipe (88 Sport) - no worse off than earlier up the exhaust stream
Two pipes of whatever size and two lers - flow more than the first half of the exhaust could ever hope for. GREAT for scavenging though, similar to the concept in that Carcraft article.
X vs H is pretty much all preference or what you can get for cheap. I run an X just because it was dirt cheap and came with lers/high flow cats/piping. Unless you're pushing 400hp+, small restrictions won't be noticed anywhere but the dyno.
Reply #55
Quote from: Seek;285308
True.  It's amazing how far most exhaust systems have come.
The S197's have 2.5" mandrel bent stainless steel tubing from the factory.  Their systems flow VERY well -- including the stock lers.
A ler swap on them is for sound only in most respects.  SOme of the aftermarket axle back ler kits have shown to flow less than the stock system :screwy:
Reply #56
Quote from: V8Demon;285358
I've seen ler tests on the S197's...between stock, no ler and a slew of aftermarket stuff, there was maybe an 8hp difference and like amount of torque...on a car with a CAI, pulleys, and a tune.
Pretty much just a sound aspect as you said.
