Topic: 3.8 Split port swap carb conversion complete! Now with Pics! (Read 21099 times) previous topic - next topic
Hey, just wanted to let you all know there is a thunderbird out there running and driving around with a 3.8SP out of a 2003 mustang with a 4bbl on it, 3G swap, Electric fan, etc.  It ONLY took me about 8 months to get it done.  :)
:ttiwwp:
X2 :beatyoass:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
So, have ya ever given a thought to the 4.2 internals...?
And pics X3! ;)
I'd be more interested if it was kept EFI, but interesting none the less. ;)
Post up some pics.
Pics pics pics!
Doh! I knew I was forgetting something. Now, I know what you're all gonna say, "Your paint sucks"
 "Why'd you cut a great big hole in the hood?"
"Why is your engine bay so dirty?!" and
"Why isn't that scoop attached properly?".
---So, the paint is bad because the previous owner gave it a cheap paint job, and I have not fixed it yet,
there's a great big hole in the hood for the ginormous aircleaner that sits at a goofy angle,
the engine bay only LOOKS dirty because the paint is worn off,
and the scoop isn't attached, because, well, I've just spent 8 months getting the motor to work and I have not gotten that far yet. So there.;)
The gauge panel pictured is CNC'd aluminum :)
--As far as the internals go, I'm just happy she runs right now. When time and finances allow, I will be upgrading the motor further, definitely stroking it out, possibly adding a blower. So, without further ado, here's your pictures:
And also...
Check out the purdy 3G alternator.  :) Thanks to JeremyB and everyone else who contributed to the Alternator swap threads!
Thats pretty cool. What intake is that?
That would be a Morana V6 Racing 2pc 4bbl special. Has anybody noticed that the EGR is still hooked up? She did fly through emissions earlier this month.
Also, does anybody have a preference on Spark plug wires? She needs a new set, and there are just so many choices!
Also, the electric fan out of an '01 Mustang is LOUD!
I like Autolite pro series wires. Nice intake. I almost swaped a 3.8 into my old ranger. It had H-beam rods, ross pistons, compcam, and ported heads. It dynoed 300 horses on our engine dyno with that intake and a 570cfm street avenger holley. We built it for someone and the guy never picked it up. My boss told me I could have it but I didnt feel like getting into a big project and I couldnt park my DD long enough for the install.
It was one of the split port motors? Built and free? And you turned it down!?:D
Well, it definitely took some modifications to make it work, as I reused my front end accessories.
That is really cool. Hows the butt dtno?
Is the bottom part of that intake a stock Ford piece, or is it a custom casting? I'm just wondering why, if it's a custom casting, would Morano Racing bother with a two-piece design instead of a traditional dual or single plane intake...
Did you put '83-'87 accessories on a 2003 block?
Haystack  --    That is really cool. Hows the butt dtno?
I like to think so.
The dyno reads "Fun!" But I do need to make improvements to the rest of the drivetrain to take advantage of this motor.
Thunder Chicken  --   Is the bottom part of that intake a stock Ford piece, or is it a custom casting? I'm just wondering why, if it's a custom casting, would Morano Racing bother with a two-piece design instead of a traditional dual or single plane intake...
Heh, yes, the lower intake is stock ford, the upper intake comes as an adapter plate and a riser, which is what you mainly see. It mounts the carb up there pretty high, so I think sometime this year I may end up working on a conversion manifold that replaces the lower intake entirely.
Also, as a side note, the manifold ordered from Morana was found to be not flat for shiznit on the parts that count(Bottom of adapter plate, carb mount) So I had it machined to flat, your experience may vary.
JeremyB  --    Did you put '83-'87 accessories on a 2003 block?
Yep. That's what I had so that's what I used. I thought about using new ones, but I asked about the accessories for the motor when I bought it and they wanted 50-100 per piece or some fool thing, so I politely declined and made what I had work. And it works rather nicely.
Although, we will see what the AC shop has to say on Wednesday.
