Topic: Mark V or VI with CFI (Read 1569 times) previous topic - next topic
I scored a large herd of Mark V, VI, or VII.  (I don't know the desigation, but there all Marks) in the junkyard.  I also have a 85' S.O thunderbird.  Can I swap the Mark CFI unit into the 85' thunderbird?  Thanks...
Re: Mark V or VI with CFI
you can, but you might have to tweak your fuel pressure a little bit, which is easily done on CFI cars
Quote from: Tbird232ci
Forgot to add that I have the 5.0 S.O...
you mentioned its an SO
as long as you have CFI, its a direct swap, the HO CFI unit has slightly bigger venturi's, and bigger injectors
