Topic: air fuel guage install question (Read 870 times) previous topic - next topic
putting a a/f gauge in a 88 tc. help if someone could let me in on which wire im supposed to tap into to get a reading off the sensor.
thanks!
It has been some time since I installed mine. If I remember correctly Pin#28 you can tap into it at the ECU plug. I used one of those Scotchloc wire taps. Then just a matter of power and ground and mounting it up. I mounted mine in the Stock dash clock location. My dual pillar pod was full already. Here is a pic of the mount before it went into the car.
I used the stock clock wiring for the power and ground then ran the one wire to the ECU.  Do some looking over at http://www.turboford.net/cgi-bin/ultimatebb.cgi?ubb=forum;f=2;hardset=0;start_point=0;DaysPrune=0&r=actu
or NATO site to confirm the pin number and how to figure out its location. It has been 2yrs since I did it.
Stuckman
Thank you!
