Topic: 306 roller shortblock (Read 861 times) previous topic - next topic
87 302 XXX block, .030 TRW forged pistons, crank turned .010, ARP rod bolts, Crane 2031 cam- specs: http://www.georgeturbox2.com/images/Crane2031specs.htm, double roller timing chain, timing cover, HV oil pump and pickup. Motor has one new piston and ring set(honed cylinder) due to a previous quenched ring set. Motor is in great shape: made over 480RWHP w/turbo and previous bad ring set. Pickup in SE PA or may meet. Pics to follow. $600.
$500, will throw in a Canton pan for $50 with block purchase.
Fml....
Quote from: DVP;283129
Fml....
Had to look that one up....
THIS is exactly what i needed for the Cougar, in the price range I set, plus more than I need. Dreaming up a 03-4 Cobra swap now....
$400
Sold
