Topic: EFI to carb (problem solved) (Read 3074 times) previous topic - next topic
this is for me as much as it is for everyone....  what is needed to convert to carb?
HLY-12-801-1 (holley red 7psi 97 gph pump)
or
CRT-M6962  (Carter 120 gph mechanical fuel pump)
LOK-KD2AODHT (lokar kickdown kit *not a problem with T-5*)
you need a fuel sender from a carbed tbird or mustang
i got the basics i need to know what to do with ignition to help me and the others to save us from any further stupid carb questions help me complete this easy parts list :D
(sticky please!)
Re: EFI to carb (incomplete information need help finishing)
Oh... and I would use the electric pump.  Otherwise you'll be tearing the front of your motor off down to the timing cover.
link doesnt work.....
Try This
got it....
ill stick with EFI heh
Re: EFI to carb (problem solved)
Good call.  I'm reconsidering my plans to convert my CFI bird over the Carb at this very moment.
yeah, go with one of those edelbrock pro flo kits
or an accel DFI setup....
I changed my T bird to carb and all i did was chop all the wires out but the 2 power feed wires and swaped fuel tanks.  if i didn't have a good tank i would have just gone with a elc fuel pump.
But i also swaped in my 351 that was already carbed.
