Topic: Liar!!!! (Read 1602 times) previous topic - next topic
Re: Liar!!!!
its obvious the person doesnt know much about the car, i think it was a case where they took it to the shop and said, "make if fast"
303 cam shaft-which one?
Blue 1:7 roller rockers-blue used to describe rockers...
Mack under drive pulleys-Mac...
Advanced timing chain-advanced timing...advanced auto timing chain
2 and a half with high flow cats-most say 2.5
2 and a half cat back with Flow Master lers-same as above
190 PSI fuel pump-thats a lot of PSI
Re: Liar!!!!
And it does the 1/4mi in 10.7, but 0-60 is 6.1 sec?? Schitttttt, yea right..(must be the stock intake holding back it back) , I'm guessing my 0-60 on the nitrous was a high 4, and still only went low 12s.
Re: Liar!!!!
wow, if thats all it took to run 10s everybody would be runnin them. that and it wouldnt be a big deal......lol
thats one STOUT mustang....i know somebody hed get along with well...
~John~
Re: Liar!!!!
shiiiitttttttttttt he must mean 40hp, and 10.7 1/8 mile.  Cause you know how fast those stock head stock intake mustangs run  " they was made for tearrin up the competition"
 :giggle:  :crazy:  :giggle:  :crazy:
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Re: Liar!!!!
shir in that case I'll be running 9's in my stang, and we all run 13s in our stock birds :loony:
Re: Liar!!!!
looks at ebay looks out window at T bird hmmmmmmm no thanks i will keep my T bird,
