Topic: Oil pressure on hot days reads low-normal? (Read 912 times) previous topic - next topic
Past few days its been extremely hot in PA and the oil pressure in the TC has been reading on the M part of NORM...when its cooler out, it reads in the N.  Is this normal behavior?  I'm going to check the dipstick tonight after work to just make sure its got enough oil.
I have never had a car read below normal if its hotter or colder outside. Or maybe I have never paid attention! lol I'd check the oil level
1971 Camaro Blown 640ci
1988 T-Top Mustang
1980 Mustang coupe
1988 Thunderbird TurboCoupe
Previous Thunderbirds:
1988 Sport
Its fine.
Think of it, our gauges are basically dummy lights anyway. Usually as long as it moves off the bottom of the gauge its fine.
If youre paranoid hook up a real gauge.
the first part of your reply there is kinda bold,,,,
the second part is better advice.
get an aftermarket in the dash oil kit and install it to take a true reading.  Atleast you will know for sure.
if it goes below 20,, the time has come to step up a viscosity level or two.  Ideal presure would be 30plus with idle rpm.
