Topic: explorer heads? (Read 1848 times) previous topic - next topic
explorer heads?
i heard that the 5.0 explorers had a version of the gt-40 heads, the gt-40p's is this true? and would they work on a '78 351w? thanks for the help guys
THERE'S NO REPLACEMENT FOR DISPLACEMENT!!
1994 ford cough aerostar cough :shakehead
1985 mercury cougar 5.8 fmx 3 speed 4.10s in progress :welder:
Re: explorer heads?
it tis true. 97s up had the gt-40ps. they require special headers because of revised spark plug location. mountaineers have them too.
Re: explorer heads?
And those special headers may prove impossible to find for a 351. Also, you'd have to enlarge the head bolt holes 'cuz 302's use smaller head bolts than 351's
Re: explorer heads?
sh*t cause there are a ton of wrecked explorers around here
Re: explorer heads?
could you use the stock manifolds? i was told i needed headers to complete my 351 swap but the manifolds clear as far as i can tell
Re: explorer heads?
i've heard of ppl using 'shortie' spark plugs to clear with some headers. that and 90* angle boots. some of the primaries may need to be 'dinged' if you still go the header route. i kinda missed the 351 part. oops. sorries.
Re: explorer heads?
Quote from: Thunder Chicken
I believe all the stock Ford heads are drilled for 1/2" bolts so they should bolt on a 351 no prob. I'm 99% sure the 5.0s use a shouldered 7/16" bolt with these heads...
