Topic: Redrilling axles (Read 1955 times) previous topic - next topic
Redrilling axles
Has anyone here redrilled their rear axles for 5 lug ? I have a friend with  3:55  8.8 rear end he's taking out of a 87 TC. I've read lots of post regarding the 4 to 5 lug conversion but redrilling was only mentioned once that I could find. I'm not sure what the axle is worth but I figure since it already has dics I'm ahead of the game. Not having to spend extra $$ on axles means I'll have $$ to buy the front spindle & brake assemblies and new 5 lug rotors.
I have a full size drill press and hole transfer punches. I figure to leave it one stud ( two if they fit) and install a 5 lug drum or rotor which I'll use as a template to mark the holes.  I have drums from my 71 Mach1 and I think some Mark VII rears I bought for the rear disc conversion for my 62 convertible. Does anyone know if the drum/rotos hubs are the same dia for 9"/8"  and 8.8" rear axles?
1974 Falcon XB-GT Coupe
1988 Thunderbird Sport
1962 Thunderbird convertible
1971 Mustang Mach1 429SCJ
Redrilling axles
I've never actually seen or heard of anybody doing it, but I have seen a pair of 4 lug axles that looked like they had slugs pressed/welded where the old studs went and the 5 lug pattern drilled in.  With the right equipment, I'm sure you could do it...but it might be cheaper/easier to just go to the j-yard and grab the necessary axles out of another vehicle.  As for the hub size...I honestly couldn't tell ya.
Good luck,
Don
