Topic: xr-7 speedometer dash bezel (Read 1147 times) previous topic - next topic
need 1985-88 xr-7 checked style speedometer bezel
xr7 speedometer bezel
Quote from: salrock54;278280
anyway to fix broken mounting tabs on speedo bezel
How about this. Super glue to hold it in place. Then Two part epoxy some thin sheet metal on the back side to add strength! Looks factory fresh yet stronger too!
Stuckman
xr-7 speedometer bezel
anybody parting out 85-88 cougar xr-7
I have the dash bezels from an 888 but they are wood grain.
stuckman
if all the mounting are good-i could  re glue them like you told me.  need the little mounting holes that are above the radio bezel on the right side.what kind of epoxy can i used-will keep  the xr-7 checked pattern.get back to me,info-thanks sal.
Quote from: salrock54;282009
Might have a couple, let me check. :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Quote from: salrock54;282037
Oh you need those. First I tell you if you don't have them start looking for small plastic rings that look close to those. They are in a tight area and you have to really look to seem them. Cut your thin metal to hold that plastic ring and onto the back of the bezel. Then I use Versachem plastic welding system part number 47809. It is made for plastic but will hold the metal too. That will hold it if the patten is messed up I'm not sure maybe pics of the damage would help. Eastwood used to make a kit to repair the plastic on the surface to match the grain and such.
Stuckman
Sorry, this is the best one I have. :punchballs:
how the shape-all mounts in tack-any marks or  imperfections-get back to me with info-thanks sal
