Topic: 6speed trans (Read 3666 times) previous topic - next topic
6speed trans
has any one put a 6 speed trans in a thunderbird yet?
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
6speed trans
Yep, Several have.
~John~
6speed trans
i might do it if i can get one cheap and after i supercharge it lol:burnout:
:birdsmily:
6speed trans
I was going to go with a D&D kit before I stopped my project. It's an easy swap.
6speed trans
whats d&d
:birdsmily:
6speed trans
o  ok thanks. im gessing if  i go with that i have to move the shifter back
:birdsmily:
6speed trans
The shifter should be very close to the stock mustang t5. At one point in time I had about 3 full pages of text I copy and pasted with 6 speed swap information. If I recall correctly the 6 speed is very similar to the 5 speed as far as the shifter goes.
6speed trans
ok thanks for the help lol im thinking about puting one in a few years:burnout:
:birdsmily:
6speed trans
Quote from: shame302;276711
Yep, Several have.
Really? Who dat?
Geez, I've been under a rock... need to become more active.
6speed trans
Quote from: Ether947;278721
Really? Who dat?
3,334 posts and you need to be more active????
6speed trans
There from the old forum. Most of us just got our post dragged over.
6speed trans
I have "seen" 3 5.0 based cat/birds and one turbo coupe 2.3 with a 6 speed. No info on any of them though cause i suck like that. In the 5.0 cars its an easy swap. It can be expensive though. It can be done "on the cheap" but its still "expensive. Id wager 1000 to 1500 easy. Mine was about 1300 by the time i was rowing gears with it and that was in the stang. Although, i suspect the only real difference would be the speedo. Cat/birds are electronic as well are they not?
~John~
6speed trans
dang so it can be done lol. i want to do it when i hop up the h.o in a few years:burnout:
:birdsmily:
6speed trans
Quote from: shame302;278802
yes sir...for sure '87-'88, assuming 84-86 are as well, but no idea on the 83's.
