Topic: Zero oil pressure (Read 4688 times) previous topic - next topic
Zero oil pressure
Well I didnt use assembly lube cause I didnt build this engine, as I said in my original post (I think) I got this whole engine from a member after he pulled it from his car. Lifters and pushrods and rockers are not okay because they dont exist :p
Anyway. As it turns out, the shaft was actually COMPLETELY missing. Whats f'ed up is that little locking ring that is supposed to hold it in was still laying in there. Only thing I can imagine is that the shaft was stuck to the bottom of the dizzy shaft when he pulled it (he kept his diz) and he was able to yank it out hard enough to pull that ring off the shaft. New shaft was $7 at the zoo.
Sooo all is well now, except... I think I did trash the cam. Theres still a good bit of noise from the top end. So my guess is I prolly trashed the bearings up there since they deal with the most friction.
At least the car is pretty much drivable though. Cam and followers and bearings in the top end is easier to replace than a total rebuild.
Zero oil pressure
Quote from: bhazard;277414
yeah, your village idiot reports to work sir:punchballs:
shows you how much i pay attention to the 2.3.
Zero oil pressure
Yeah the poor thing never gets attention.
Zero oil pressure
Does the RR cam use hydraulic lifters (or followers, or whatever you OHC guys call 'em)? If so you may have simply collapsed 'em from running with no oil pressure, and they may simply need to be pumped up again...
Zero oil pressure
Im hoping thats the case.
Zero oil pressure
The correct term for the 2.3 lifters are lash adjusters... Works same as a lifter but doesn't move, just keeps a constant pressure on one end of the rocker...
Zero oil pressure
The correct term for the 2.3 rockers are followers... I believe they do roughly the same thing :p
