Topic: Largest Tire Combo (Read 2032 times) previous topic - next topic
Largest Tire Combo
Just curious. Didn't someone post a thread that they had put either 305's or 315's size tires on their '87 or '88 T-Bird. If not, can a 305 or 315 size tire on a 18" rim be modified to fit in the rear of a '87/'88 T-Bird?
Ride the Thunder & Feel the Power
Largest Tire Combo
With a mustang 8.8 and the right back spacing you can fit a 295 for sure. I'll have to talk to my buddy and see if he remembers the back spacing on his rims(he's still able to run quad shocks). There is enough room for 305's but even with the 295 you will get some rubbing if your rear springs are getting soft, especially if you have people in the back.
These are 295's on a 15x8 rim, mustang 8.8, and quad shocks.
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
Largest Tire Combo
Thanks. I've seen the T-Bird guy "HawK" car in cardomain and he has 295's but I'm not sure about the quad shocks.
Largest Tire Combo
Nice XR7! He just out of curiousity, are the XR7's Left half and right half fenders with the cornering lamps, interchangeable with the T-Birds. Of course using the same year type, 87-88.
Largest Tire Combo
Hawk's rims are custom made one off's so i think his offset is also custom.
Mine being stock offset 22mm 18x10s, i run 275/35/18s with quads and stock fender lips.
This however is the largest you can go and still retain,stock rear,1/4 lips,quads and exaust which was my goal.
Largest Tire Combo
Quote from: Thor Power;275491
Yes.I just cut holes in my"no light"fenders the same size as the factory "lighted" fenders on my blue Bird(took about 10 minutes,,a cutoff wheel,some masking tape,and a Sharpie marker).That way I didn't have to swap fenders and worry about paint.The lights are held on by the fender trim fasteners.Just get the lights and trim pieces,and whatever you need to wire them up (harness,relays.........).
Largest Tire Combo
tires ive had under my old car rolled lips on the 1/4's
28-10.5W-15 (in pic)
325/50/15
315/35/17
Largest Tire Combo
Let me get that maverick! lol
1971 Camaro Blown 640ci
1988 T-Top Mustang
1980 Mustang coupe
1988 Thunderbird TurboCoupe
Previous Thunderbirds:
1988 Sport
Largest Tire Combo
WOW! Thanks for the mod advice "Vinnietbird"! I think I'll start that next weekend ( or after I secure those lights..I seem to already have the wiring for it)
Largest Tire Combo
Here are some 315/35-17's:
If you don't change the axles, you end up with this:
