Topic: 1988 TC single Holset turbo 5.0/ 4R70W (Read 371148 times) previous topic - next topic
Reply #915
After saving some cash up I have decided to go with a used set of TW heads. I am excited to get these on the car and see the difference. It will give me a chance to fix a couple of things that I want to improve on with radiator shrouding and isolating the airflow to the turbo inlet. I can also take a look at the wideband once the passenger inner wheel well is removed to fix it.
At the same time I'll be getting the A/C hooked up and charged so I can drive and enjoy the car during warm weather. Stay tuned!
Reply #916
That is cool Jim...  What size TW heads?  I would assume aluminum....
Im running into C4 bellhousing, flexplate, torque converter problems.  It looks like I some how got the super rare Mustang II one....which doesnt match anything....grr.
Travis
Reply #917
170's with uprated springs. Should be a nice fit for my combo.
Bummer on the troubles you are having. A bell shouldn't be too hard to come across. Just a little snag. Lord knows I've had my share as well!
Reply #918
Quote from: turbotrav;395163
Travis
Hey, I've got one of those!  They are quite small and very shallow.  I believe the flex plate is specific to the bell too.  I been sitting on it for a few decades....
Reply #919
Quote from: flylear45;395177
You should see the heads & other stuff tomorrow!
Reply #920
Not to hijack jims thread but will the small one work on the 351 in our cars.  I found the spacer on eBay for $30 shipped.  I already have the bellhousing, TC, and flexplate?  Put a post on corral with no response
Travis
Reply #921
Quote from: 86T-bird;395181
Cool! I don't have a clue when I'll get started on it. The Tr7 is first up for repairs, and I am reworking the alternator mount on it as well as repairing the damage from a sheared aux gear.
Your offer was too good to pass up, though. I am grateful.
Reply #922
Quote from: flylear45;395200
You've got some cool projects, glad to help out getting one moved to the next phase!
Reply #923
Quote from: turbotrav;395190
Not to hijack jims thread but will the small one work on the 351 in our cars.  I found the spacer on eBay for $30 shipped.  I already have the bell housing, TC, and flexplate?  Put a post on corral with no response
Travis
There shouldn't be an issue with fitment in our cars behind a 351.  The small bell provides plenty of clearance.  As you install the converter and mate to the block, check the clearance.  The shallow bell can place the converter too close to the flex plate, potentially causing it to bind.  It's a lot easier to check out of the car!
Reply #924
The swap isn't bad. I did mine in about 6 days working for 2 hours or so a night after work.
Reply #926
Nothing to update. Still running it around as it is and playing with transmission software.
Every once in a Blue Moon........
Reply #927
X
You see a Thunderbird
Reply #928
Very nice.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
