Topic: 1988 TC single Holset turbo 5.0/ 4R70W (Read 372920 times) previous topic - next topic
Reply #225
I usually have a pretty 'easy' job. Today's weather really kicked my butt mentally. I don't even feel like working on the car. I got to the point today where I just didn't want to have to make another big decision. Managing a 15 million dollar asset can be a bitch! Especially with the pressure of toting the top execs on a py day, telling them they can't do what they want to do.
BUT, I wouldn't love to fly after 25 years if it was always easy.
And, it's nice to get the pat on the back at the end of the day from the Chairman and my boss, telling me he knows I did all I could do.
Yeah. I like to make the hard decisions.
Reply #226
Sometimes I wish I made the hard decisions. I need more $
Reply #227
Tried and tried to get the intercooler silicone to fit today. No way it would work without modding the intercooler or turbo cover.
SOOOO, I moved the intercooler forward again to allow me an extra coupling to get it plumbed. Now I just have to modify the cover brace and make new intercooler mounts and I think it'll work out. Third time is the charm!
Reply #228
Here's the latest mock-up with the painted charge pipe, the line and fitting for the turbo oiling/ oil pressure gauge, and the charge pipe silicone installed.
XXX
Reply #229
Pretty. You know your cars gonna probably be just as scary with street tires as that code red mustang?  Can I go for a ride?  :hick:
Reply #230
seems to me that this would have all been so much easier had you just dithched the ac like I plan to keep mine:hick:
But then again where's the fun in that?:p
I can't believe your still sane after all this re-plumbing...
Reply #231
There is nothing cooler than blowing the doors off some chevy with the A/C on.
Reply #232
Quote from: thewestie;354075
No, this will be less than 1/2 as scary if I get the HP output I hope for. The 5.0 blocks split around 500, so I'm shooting for 400-450. Sure, I'd take you for a spin if you want to.  The turbo TR7 is a hoot, too.
Quote from: sarjxxx;354079
I am just stubborn, not smart. ;)  I already gave up ride control, I'm not giving up on A/C.
Quote from: Bruce M;354097
This should be a 'sleeper'. They won't know what just happened. :)  Beaten up by a Granpa car.
I just priced out the paint recently. Looks like to get enough base/clear in the factory silver, plus hardeners, reducers, and such will be around $400.00. I could save $100.00 if I went with a generic silver, but I'd rather stay stock.
Reply #233
Quote from: flylear45;354107
No, this will be less than 1/2 as scary if I get the HP output I hope for. The 5.0 blocks split around 500, so I'm shooting for 400-450. Sure, I'd take you for a spin if you want to.  The turbo TR7 is a hoot, too.QUOTE]
They now make valley girdles for the 5.0 that adds a lot of strength, that and the main girdles keep the block from twisting.
Reply #234
Yeah, I've seen them. Unfortunately they don't always do much. Check out the carnage sometime over at Turboforums.
I'm just gonna stay conservative on this one until I can build an aluminum head 351. Then maybe go a little crazy.
Reply #235
My friend at The Head Shop just built a 408 for some guy thats running a turbo and NOS, but he used a Dart block. He's shooting for about 750+ HP. Oh and it's going in a Lighting. You turbo guys are crazy!
Reply #236
Sounds good. Nobody has split a Dart block that I ever heard of.:iagree:
Reply #237
Quote from: CoogarXR;350636
You could also make a plexiglass plate to fit in the original rectangle hole. Back-paint it black and mask off the oval where the shift indicator is (so it shows through). Have a slot cut for the shift lever, and do the brush thing mentioned above (or rubber flaps). You would end up with a black shiny plate that has the shift indicator shining through. Kinda like this, and put the brushes in the shifter slot:
You know, the more I think about it the more I like this idea. If I just attach a light to the shift handle along with a red pointer, and mark the places where each detent rests, I could end up with a pretty nice looking plate that can be sized to fit the console pretty well.
Woohoo!
>5,000 views!
Now I have to finish it. LOL
Reply #238
Fitting up the nose for the first time. I may be able to get a filter on the turbo with a couple of elbows and some cutting of the metal radiator shroud behind the headlight.
XXX
Reply #239
Two more:
XX
