Topic: 1988 TC single Holset turbo 5.0/ 4R70W (Read 371114 times) previous topic - next topic
Reply #1050
Quote from: thewestie;426600
I like the red but Im  a big fan of red
Happy new year
Happy New Year to you too, bud.
I'm thinking I'll stay with the red for now and maybe paint the upper intake plate letters red.
Reply #1051
Quote from: STANG8U;426603
Intake came out nice
And I just saw someone do the same thing on the corral
The breather thing too, or the tall covers?
I'll have to go take a look.
Thanks!
Reply #1052
There breather set up where the exhaust pulls it
Reply #1053
A lot of dirt cars near me do that trick, using the exhaust to create vacuum in the crankcase.  See it all the time.  One way valve plumbed into the collector, each header has one, going up to each valve cover.  Heard you get 8hp on a built 358SBC
Love Foxes, Birds or Stangs.
Reply #1054
Quote from: MechanicMatt;426619
Yeah, I guess pulling a vacuum helps keep the rings sealed for more HP. That's secondary for me on this build. I'm trying to get rid of blow-by pressure under boost and eliminate the PCV without sacrificing oil life at all. It's pretty amazing the Ford engineers did so well on the 2.3 turbo. One crankcase mounted oil separator tied to a PCV into the intake and a top of valve cover oil separator to the turbo inlet.  Works real well even with twice the boost of a stock configuration.
Reply #1055
Geez...Jim quite abit done is a short period of time...It must be cool to live that close to summit....nice.
Good luck,
Travis
Reply #1056
Quote from: turbotrav;426663
Good luck,
Travis
I work reasonably fast once I get started. I am slow to start though. I tend to think too much, or just drag my feet when it comes to tearing the car apart when it's running. I've been sitting on these heads for a year.
It is nice being close to Summit. If I am not in a real hurry I can order online and parts usually show up the next morning via Fedex. They are putting a Harbor Freight store in Streetsboro now. That will be nice for junk tools and some misc. supplies I use.
Reply #1057
Gotta love Harbor freight lol
Reply #1058
Injectors came today, catch tank showed up yesterday. Now I have all the last bits I need to get 'er done. I still have a lot of time to put into the headers/ hot side before it's ready to bolt on, though.
Reply #1059
The two things I ever bought from HF....have already broken....cheap tools is being a bit kind.
Travis
Reply #1060
I spent all day sanding and prepping the headers and hot side. Sprayed 'em with VHT Ceramic and installed them. Got the injectors in, hoses connected at the rear, all the wiring re-connected and the upper intake on. Bolted on the turbo and drain. Welded in the vacuum venturi to the downpipe. Swapped around the breather from the back of the right to the front of the left. That way oil doesn't slosh up into the breather under acceleration.
Done for today.
X
X
X
Reply #1061
More.
X
X
X
Reply #1062
The last.
X
X
X
Reply #1063
I decided to do a test and paint the crossover in stove black again to see if there is a difference in weatherability. (that's probably not a real word.)
