Topic: found a... (Read 1122 times) previous topic - next topic
found a...
I just got a 2.3n/a and 5-speed trans from a mustang for $80 bucks. The cool thing is it has a mechanical clutch instead of the hydro. I didnt think 2.3 Mustangs had those? I LOVE Craigslist  :D
found a...
But why would you want one,there junk and the trans won't hold any real power?????????????
It's not at all the same as the 2.3L turbo.
found a...
The 2.3turbo and N/A motors used the same trans.  It has the same gearing and torque capacity.  The V-8 T5's had a higher torque rating and different gearing.
found a...
jangus...that's what i thought...glad i wasnt wrong!  I was more interested in the bellhousing to get rid of the hydro clutch.  The idea is to find a ranger with a blown motor for a couple hundred and r2 it with this.
found a...
Having driven both, I prefer the hydro cluch.  Not to mention I don't have to worry about the stinking cable breaking.
found a...
A lot of the Rangers had hydro clutches IIRC, I know my 87 did.  I used a Gen 1 clutch master with the TC slave.
And yes, the NA 2.3 T5's are the same as those used on the 2.3Ts.  To know what you really have, look up the code on the tag on the case.
found a...
My bad the trans is still a world class if it's 85-on,however according to parts stores on the net there are different part #'s for some of the parts contained within the turbo and non turbo t5's.
This would mean that they are in fact different.
Here is one parts listing i got off the net,there are many more for different parts in the trans:
Ford
     Borg-Warner T5 "World Class" 5sp, 4cyl, 6cyl, 8cyl
   85-on
   Alum Case. Cast "13-52", Fiber Rings. Uses LM48548/LM48510 Input Bearing.
   BK149    BK149WS
     Borg-Warner T5 "World Class" 4cyl Turbo & 4cyl EFI, 5sp
   86-on
   Alum Case. Cast "13-52", Fiber Rings. Uses M88010/M88048 Input Bearing. Assy #'s: 1352-000-154, 155, 162, 194, 209
   BK149A    BK149AWS
     BW T5, World Class, Cobra Mustang
   93-95
   Alum Case. Cast "13-52", Fiber Rings Uses LM48548/LM48510 Input Bearing. Uses Tapered Pocket Bearing. Assy Codes: 1352-000-218, 239, 242, 249, 251/3
   BK149C    BK149CWS
