Topic: 4.6L DOHC into 88 TC (Read 7957 times) previous topic - next topic
I know there was a project a year or more ago that was eventually given up... to put a 5.4 into an 88 FoxBird.
I've read a lot of articles etc. of people putting 4.6L DOHC in Fox body Mustangs.
Anyone know of a 4.6L DOHC being put in an 88 TC and fitting it under the OEM hood?
I REALLY would like to do that swap.
1988 Black Turbo Coupe
1989 Fiji Blue Chrysler Conquest
1990 Silver Lincoln LSC MKVII
2003 Black Mercury Marauder - S/C
1967 Green Ford Fairlane
:burnout:
32VFoxBird was the one, but IIRC, it sat too tall for a stock hood?
1987 TC
Quote from: HAVI;274684
He was also doing a 5.4 which is, I believe, taller than the 4.6.  I was reading an article on line (Car Craft I think) where they put a 4.6 DOHC in a 60's era Mustang and spaced the k member down a bit so it all fit under the hood.  I know they make tubular k members for Fox bodies for either 4.6 or 5.0.  Just wondering if that k member is designed so the 4.6 will sit low enough in the car to fit under the hood.
Was hoping someone better than I had already been down this road and could fill me in.
:burnout:
im thinking it ~could~ fit under the stock hood. hell a 5.4 can fit under a stock sn95 hood.
~John~
spacing the k member for clearance would work, then you have to make up the difference with the suspension. when i was doing mine i went with the AJE 4.6 into fox k member and would still recomend that.
~John~
Quote from: shame302;274687
Shame,
Have you actually done this?  Do you have a 4.6 in an 88 Thunderbird?
:burnout:
Nope, Bailed on it last min. for the mustang (Halfbreed). Halfbreed IS basically the tbird but its all in a Y2K mustang body instead. Had 95% of my parts to do it. Just needed to build it. Not a big deal really provided you have everything you need, It's just involved. TONS of modular 4.6 DOHC into fox info on the web.
~John~
There is a guy in Brooklyn NY that has one-4.6 liter in a 1988T/C no spacing of the K-member needed. They used a mustang k-member for the install( SN-95). They also used the hydrobrakes from the mustang because the T/C master cylinder was too long.
Quote from: kendoo130;274764
Ok... did they manage to fit it all under the OEM hood with no clearance issues?  Was it the DOHC?
:burnout:
It was under the stock hood(88 T/C hood). the only thing they had a problem with was the T/C master cylinder. The car still had power steering and A/C. It was a SOHC. I haven't seen this car or owner in about 12-13 years. I do however speak to the mechanic that actually did the swap.
I wish I could give a definite answer, but I used a Sullivan intake with a carb. I know the hood closed without the carb on. :)
1979 Ford Fairmont
[/B]
Quote from: kendoo130;274812
Could you get me a contact email address for that mechanic?
Do you know if the car was an Auto or did they do a Manual trans?
:burnout:
Quote from: 32VFoxBird;274813
You were working with a 5.4L weren't you?  I remember following your build.
I am hoping that the aftermarket K member would take into account some of the engine height and locate it slightly lower in the car.
:burnout:
With an AJE K member and the hydroboost setup you "should" be able to fit under a stock hood. If you want power brakes you will need hydroboost. I didn't actually do it in the tbird so i can't say for sure but im pretty sure it will fit without putting spacers between the k member and body. I was prepared to do si if need be though. No way was i running anything other than a stock turbocoupe hood......
~John~
Quote from: shame302;274817
Do you still have the K member?
:burnout:
