Topic: Need igination help (Read 1505 times) previous topic - next topic
Need igination help
Need a wire that comes on with key and stays on when cranking. Current red with green strip turns off when cranking. I can not even find one on the colum????
85 t-bird
Need igination help
Should be that red one with green stripe. Grey/yellow stripe would be power while in "Run" but not while cranking.
Need igination help
so what one do a connect to my red ignition wire on the msd box if I use the red w/ green strip in will fire the msd box when in run mode but not while I crank.  Does the msd box know when to fire?? Since it has a postive comming from the battery?      msd6al
Need igination help
Like Thunder Chicken said use the R/LG wire. It is hot in both Start and Run.
It goes to the coil and went to the TFI ignition module.
Need igination help
Mine goes off when the key is in cranking pos. Pulled dash apart tested all wires on the switch none are hot at both postions. I have put the car on a major wire diet. Maybe I pulled somthing out I should't have.
Need igination help
BR/PK wire #262 from ignition swt. terminal 12 is hot in START.
R/LG wire #16 from ignition swt. terminal 11 is hot in RUN.
The two are spliced together at S296
C403 a brown connector with 3 terminals, C232 a brown connector
with 6 terminals and S296 are all located behind the left headlight.
