Topic: Welding sugestions (Read 10322 times) previous topic - next topic
Welding sugestions
So I finally got a chance to practice welding again after a few years, and taking a brake from wrenching on my car. I took a fender and tried to make some beads on it, I set the welder to what the chart said for .032 wire then adjusted the speed up or down a little. I know .25 wire is preferred but this is what was in the welder so I was decided to go with it for now. I made one hole and then filled it back in with weld, but I was not able to really make any beads. Guess its been longer then I thought. I was wondering what I was or was not doing correctly any advise?
The browner area is the hole I filled in. It was about the size of a dime.
I had a hard time getting clear pictures as well.
Welding sugestions
Too much heat.
1987 TC
Welding sugestions
Quote from: HAVI;274660
Too much heat.
and not enough wire.........
[/IMG]
Just enjoyin the ride!!!!
Welding sugestions
If your welding sheet metal and body panels, You need to use 023 wire or you'll never be able to weld it correctly. Are you using gas with your welder?
The thinner wire will be a huge difference in what your trying to do.
What kind of welder are you using?
Welding sugestions
Ah 023... I was thinking 025, would 025 work if I cant find 23? The welder is a Lincoln arc welder "weld pack 100" is all it says. It did have gas set up for it but I don't have a bottle now. I am pretty sure it is set up to run without gas, for gas isn't the - + reversed?
I'll mess with the speed and temp some more I guess. In laymen terms A is cold and D is hot right? the thing that sucks is there is no in between only A,B,C,D
Welding sugestions
It'll be tough to weld sheet metal with out a gas setup. You'll have to use to much heat which will end up distorting the metal. The thinner wire will also lower your heat required to weld.
Are you using flux core wire at the moment?
Welding sugestions
I just looked and I think the wire is for gas setup. Couldn't tell because the label was torn but it said something about gascore or something to the lines of that. I'll see if I can get some wire tomorrow and talk to my dad and see if he has a tank, I think he was out that's why I didn't grab the bottle with the welder.
Welding sugestions
.023 and .025 is the same  there is .023  .030  .035  .045 ect as standard sizes
2 88 TC's (1 is the 2.3t race car, other v8 maybe?)
06 dodge dakota 4.7 v8
79 chevy k-10, built 350/turbo 350
Diverse ain't I?
AMSOIL Dealer
Welding sugestions
How can .023 and .025 be the same?
Welding sugestions
thats what I have been told. they use the same tips, and everything.
Diverse ain't I?
AMSOIL Dealer
Welding sugestions
Mine uses different tips. 025 wont go through a 023 tip.... I tried. LOL
Welding sugestions
oh ok lol which welder do you use?
Diverse ain't I?
AMSOIL Dealer
Welding sugestions
I got a Lincoln 140c
Welding sugestions
You need shielded wire without gas. Or ruff it like what your doing.
Welding sugestions
So far Ive been happy with my HH210 running C25 .023 for thin stuff
Diverse ain't I?
AMSOIL Dealer
