Topic: Power outlets (Read 1473 times) previous topic - next topic
Power outlets
The single cigarette lighter isnt going to cut it much longer. What I want to do is hook up at least 2 more to be used for power outlets.
My questions are about how should I wire them?
I will be using them mostly for my phone charger, FM transmitter, and iPod charger. Eventually a navigation too.
Where should I wire from? Assuming I could use some empty slots in the fuse panel.
Would running all of these cause any issues?
Going for factory installed look so I am mounting them out the side of the console. Not sure where yet though. Was thinking at the front where it slides under the dash but clearance might be an issue.
I know I could just go buy one of those 3 to 1 adapters  but I dont like the way they look or the extra room they take up.
Power outlets
I would just put in my own wiring with inline fuses near the battery if it were me. If your not too tall our bigger around, you could put them behing where the ash tray goes by your knee. If you don't have an eq or anything you could make a plate and mount them where the little cubby hole thing goes in the radio slot thingy.
Not the best visual, but I can't sleep tonight.
Power outlets
Why not just get a couple of those power outlets instead of using cig lighters?
I want to add one to the TBird and I need to relocate/remove the cig lighter in the Scorpio.
The outlets would look cleaner as they have a cover, etc.
Power outlets
Quote from: Haystack;274384
I am hoping I can fit them on the side of the console and still have the look I have in mind. I use my cubby thing but I could remove the idiot light panel since it isnt wired up. I just dont think I would like the look of it.
I got what you were saying. Sleep is over-rated anyways.
Quote from: Chuck W;274412
Regular outlets or the ones that look like a lighter?
I was planning on using the ones that look like a lighter that have the flap covers. I was under the impression they were the same thing, one just came with a lighter and the other with a cover. Are they different and what is the wiring like?
Power outlets
There is a difference in them. The Lighter style is a full metal job and works the lighter. Then the power outlet ones aren't made the same. They normally have plastic down inside the hole and are not made to work with the lighters, but work great for the power accessories. As far as wiring they should be the same.
Stuckman
Power outlets
I have a quad power outlet i mounted to the right side of the center i/p (basically next to the passangers left leg.
I pulled circuit breaker power from the solenoid and obtained a ground from the skeletal system of the glove box support.
done.
Power outlets
that's why i keep a power inverter tucked under my seat, with a 3-way adapter thingy.
1979 Ford Fairmont
[/B]
