Topic: Quick 2.3 Question (Read 1227 times) previous topic - next topic
Quick 2.3 Question
Do you have to take the intake loose to remove the fuel rail? I want to clean/test my injectors, and just wondered if the gurus have any tricks.
CoogarXR
CoogarXR : 1985 Cougar XR-7
Quick 2.3 Question
You don't have to remove the upper, but it might make it easier to get the rail out, esp if it's been on a while and the injector o-rings have gotten a little hard.
Quick 2.3 Question
How do you do it then? Take the bolts out, disconnect the lines, pop it up, and slide it out through the front?
I did one of these about 15 years ago, but I took the intake off. I am trying to save money not having to buy gaskets and such... I am gonna have to cash in my change to buy o-rings (I'm that broke right now!)
CoogarXR
Quick 2.3 Question
Quote from: CoogarXR;272927
Pretty much.
Quick 2.3 Question
ive always used a pressure cleaner to clean injectors no removal required.
mines similar to this but made by echlin(napa)
http://iepen 15lahoma.com/images/LS1_3.jpg
Quick 2.3 Question
I just wanted to pull them and "test fire" them and clean the screens.
For the record, I was able to do it without pulling the intake. I did have to go get a duckbill line tool though ($12).
CoogarXR
