Topic: Complete 347 Setup - New, Never Ran (Read 597 times) previous topic - next topic
My complete 347 is up for sale.  Everything listed is brand new, and in the original boxes as applicable. The long block has been assembled by CHP and has been sealed, sitting in the crate in my garage for the past few years. I just haven't found the time or money to finish the car.
The short block is a CHP Street Fighter Pro 347 (all forged internals) built with 10.5:1 CR and 28oz balance, with some upgrades to the original package, such as upgraded ARP fasteners and stud girdle. The heads are AFR 185's. I want to sell everything together as a package deal. This is a complete motor, top to bottom, with all ignition, fuel, and intake components.  All you would need are a couple accessory brackets and pulleys. Here is the parts list of what is there:
CHP Street Fighter Pro 347 10.5:1CR
AFR 185cc 60cc Heads
Ed Curtis Custom Grind Cam (Spec Avail)
ARP 1/2" Head Studs
CHP Billet Double Roller Timing Set
CHP Front Cover
CHP Timing Cover bolts & Seal
CHP Hydraulic Roller Spider Retro Fit
CHP Street Fighter Main Girdle
Canton 7 Quart Oil Pan
Felpro Gasket Set
FRPP 1.7 Roller Rockers
FRPP Roller Lifters
Manley One Piece Push Rods
Melling High Volume Oil Pump
Edelbrock High Flow WP
AGR Performance PS Pump
TF Track Heat Intake Manifold (Black)
Trick Flow Valve Covers (Black)
Power Bond Balancer
SFI 28oz Flex Plate
BBK 75mm Throttle Body
Pro-M 75mm Chrome MAF
FRPP 30# Injectors Flow Matched
Kirban AFPR
FRPP Chrome Water Neck
Stainless Engine Bolt Kit
Generic Chrome CIA
MSD Pro-Billet Distributor
MSD 6A Ignition Box
MSD Blaster Coil
MSD 8.5mm Wires
FRPP Red Wire Seperators
PowerMaster 140 Amp Alternator
K&N 9" Cone Filter
K&N Gold Oil Filter (x2)
Looking for $8999 for everything listed, plus shipping, or pick up in Lincoln, Nebraska.
I know I do not have very many posts here.  SSX knows me, and might even vouch for me. ;)  I'm a longtime resident on SCCoA and TCCoA as well, so feel free to check up on me.
Thomas
