Topic: Bostonian Ed Coach Lamps (Read 1046 times) previous topic - next topic
I've got a 1988 Cougar Bostonian Edition.  The coach lamps (located on the door pillars don't work.  Does anyone know the best way to test these to see if it's the bulbs or the wiring?  I'm not sure how to access the bulbs.  Any ideas there?
Thanks in advance!
Mark
I'm not aware of any '88 with coach lamps but as long as its not like the earlier coach lamps then it might just have a regular bulb underneath.  You'll probably have to take the rear seat cushion (bottom part) out and pull your B-C pillar (read Quarter panel) trim out.
