Topic: My A/C is giving me cold feet! (Read 1673 times) previous topic - next topic
Okay, so I’m driving along, minding my own business (Don't I always?). It’s pretty hot outside, so the A/C is blasting away, blows pretty cold. I go for a quick right turn and BLAM!...my right foot freezes! Actually, it’s soaking wet—from ice water! I conclude that it’s obviously condensation off of the evaporator; apparently has no where to drain. My question is: is the condensation normal? If so, IS there a drain for it, and perchance could it be clogged?
Yes yes and yes.
Lol!...Succinct and to the point! Love it!....Well, thanks, that answers those questions!...now I guess I gotta get under the dash and find the drain tube....any pointers before I get to rippin stuff out?
Drain tube exits into the engine compartment... It's down low, about where the fire wall curves under, just about directly below the AC lines...
Here it is. Big rubber plug with a short snout in the middle. You can probably reach it from under the hood, squeeze and wiggle it, or shove a pencil up the snout to dislodge any  plugging it up.
Cool! Thank you all for your comments! It's been a great help!
Okay, I finally got under the hood this weekend. I found the drain tube and snaked a piece of antenna inside...I'd say I pushed it in about an inch before I got a steady stream of water coming out! I'd say about 1/3 of water or so was under the dash!...things are much better now! Thanks again for the help guys!
